[UI Bug] ATRM50 WebUI Power Socket Pinout Diagram Contradicts Official Wiki
I am setting up a new ATRM50 router and while checking the pinouts to wire a custom M12 power cable, I noticed a clear discrepancy between the WebUI diagram and the official Hardware Wiki.
Device: ATRM50 Firmware Version: RUTOS (ATRM50_R_00.07.21.3) Page: Services > Power Control
The “Power socket pinout” graphic at the bottom of the page has two mistakes compared to the official hardware datasheet/Wiki:
1. Swapped Input Pins:
  • In WebUI: The Ignition pin (Green) is shown on the bottom-left, and the Low Battery pin (Yellow) is on the bottom-right.
  • In Official Wiki: The Low Battery pin is on the bottom-left (under Power), and the Ignition pin is on the bottom-right (under GND). The WebUI has them reversed.
2. Incorrect Voltage Info:
  • In WebUI: The Power pin label says “(+9-48 VDC)”.
  • In Official Wiki: The supported voltage is “(+9-50 VDC)”.
Since the ATRM50 requires users to wire their own M12 cables, relying on the WebUI diagram could lead to incorrect physical wiring for the Ignition and Low Battery detection features.
Could you please pass this report to the R&D / WebUI development team so the graphic can be corrected in an upcoming RutOS release?
I have attached screenshots of both the WebUI page and the official Wiki diagram for comparison.
Greetings @erkntncr,
Thank you for sharing your insights. I have forwarded this information to our R&D team and will provide an update in this topic as soon as I receive further details.
I’m facing the same problem.
Unfortunately, it’s not entirely clear what the pin configuration of the connector is.
The information in the manual refers either to the connector on the device or to the connector coming from the power supply.
Could you please provide a clear diagram of the pin configuration, labelled and specifying whether it refers to the device or the incoming cable?
Many thanks in advance.
Please accept my sincerest apologies for the delayed response.
Could you please confirm whether the reported issue is still occurring and whether any further assistance is required from our side?
I look forward to your reply.
All the best,
