Have two TSW212 on test, the application is to go from 1GE DWDM sfp to RJ45.
Is there a way to show optical values of the sfp in the gui ? I can see them using ethtool
root@TSW212:~# ethtool -m sfp2
Identifier : 0x0b (DWDM-SFP)
Optical diagnostics support : Yes
Laser bias current : 92.040 mA
Laser output power : 1.2359 mW / 0.92 dBm
Receiver signal average optical power : 0.0001 mW / -40.00 dBm
Module temperature : 47.32 degrees C / 117.18 degrees F
Module voltage : 3.2134 V
Alarm/warning flags implemented : Yes
Question 2:
The two sfp slots seems to behave differently, if I move the sfp from slot 2 to slot 1 then the laser will not start. Is there a technical difference between the two ports?
root@TSW212:~# ethtool -m sfp1
Laser bias current : 0.000 mA
Laser output power : 0.0001 mW / -40.00 dBm
Module temperature : 44.12 degrees C / 111.42 degrees F
Module voltage : 3.2398 V
Kindly
Magnus
