What’s the difference between these firmwares?
TSW2_R_00.01.06.3_WEBUI.bin
TSW2_PROFINET_R_02.01.06.3_WEBUI.bin
both seem to have profinet capabilities?
Good afternoon,
The main difference between these two firmwares is that with the Profinet FW, Profinet would still be switched on after firstboot.
If your use case does not require you to specifically use Profinet FW, with Profinet protocols, I would recommend installing the Latest FW instead of Profinet FW.
Arturas
