Tsw202 PoE power consumption via cli
Hello everybody,
is there any way to read the power consumption of any attached PoE device using a cli/ssh command for the TSW202?
Thank you!
Markus
Yes, there is a way of doing it via CLI/SSH. It can be checked using ubus command.
For checking information about all ports you can use this command:
ubus call tswconfig.poe get
2024-04-16-12-29-41-192.168.50.193
And for cheching information for specific port json filter can be used too:
ubus call tswconfig.poe get | jsonfilter -e '@.port7'
2024-04-16-12-36-02-192.168.50.193
Marijus
Dear Marijus,
thank you!
Is there any documentation available for the cli/ssh functions like ubus / uci? Are there other specific commands that I should know of when working with RUTxxx and TSW202?
Kind regards
Markus
Dear Marijus, in my TSW202 this is not working:
root@Teltonika-TSW202:~# ubus call tswconfig.poe get
Command failed: Not found
I am also not able to disconnect any PoE power / power cycle the PoE device. No matter if I use the web interface or the ssh function.
Strange too: the web interface does not show my an indicator / power consumption of the device attached, although it is owered on.
Kind regards
Markus
Could you please take a screenshot of the Status → Overview page? Also, could you execute this command:
ubus list | grep tswconfig
and send me the output?
Additionally, does PoE work for you? Can devices be powered over PoE ports?
Thanks,
Marijus
