TSW202 lldp info
Hello. Trying to setup a couple of TSW202’s in my network.
But it doesn’t look like the teltonika’s are sending their management ip in lldp messages.
it says ip is 0.0.0.0.
I have management in vlan139 with adress assigned from DHCP (it gets an ip and i can login to gui on both the vlan1 and vlan139 IP) all ports on the switch have vlan139 tagged and vlan1 untagged.
If i disable the vlan1 interface it seems lldp is also disabled… (also snmp seems to stop working)
Also it would be nice if it would send the device name in the lldp message
ps: i have changed the vlan1 adresses to be unique to each switch, so there is not a ip-conflict
