TSW200 Switch constantly blinking
Hello
i have a TSW200 8 + 2 Port PoE Switch here. I connected it to a 48V Power Supply.
And the LEDs blinking constantly, even nothing is connected only the power supply.
What can i do?
Good afternoon,
The power supply you are using is in 7-57 VDC range.
Are you able to try a different power supply to see if there is any difference in performance?
If the issue still persists, I would recommend contacting your distributor for an RMA form.
Arturas
Yes i tried a different one too. Device acts same as before.
