After removing and replacing the battery on E-scooter segway ninebot max, the speed limit in all modes becomes 6 km/h. You can set limits manually with command " scsetspdlim", but the situation will repeat after the next battery replacement. What could this be related to?
Kindly check if the speed limit from all modes is still there after you removed the TST100 from your e-scooter, we need to confirm if the TST100 is causing the issue, once you confirm it you need to contact your sales manager If you don’t have any contacts with our Sale managers, don’t hesitate to get in touch with them on our official website https://teltonika-gps.com/ and click on the “Contact Us” button. When you will click, please fill out the form and submit it.
Note: as a topic, please choose “Vehicle telematics”. Or you can send an e-mail with a description of your situation to info@teltonika.lt When contacting Us, please provide:
IMEI
Logs
Configuration file
International GSM number
Firmware version
You can also create a ticket through the Helpdesk.
