Hi community,
I would like to know if there is a way to monitor the voltage or presence of the external power supply on the TRM142 modem.
Is the voltage read by AT+QADC=0 related to the external power supply?
Christian
Hi community,
Christian
Thank you for reaching out.
I will clarify with our R&D department whether the TRM142 supports monitoring the external power supply.
I will get back to you once I receive their response. Thank you for your patience and understanding.
T.
You can estimate the TRM142’s supply voltage by sending AT+QADC=0 to the modem. This command measures the voltage after it passes through a voltage divider. The TRM142’s voltage division coefficient (K) is approximately 0.084.
To estimate the supply voltage, take the second number in the +QADC response and divide it by 0.084. The result is in millivolts. For example:
With a 9 V supply, the modem returned +QADC: 1,752. Dividing 752 by 0.084 gives approximately 8.95 V after conversion from millivolts.
With a 12 V supply, the modem returned +QADC: 1,1012. The same calculation gives approximately 12.05 V.
Please treat these values as estimates
T.
