Is there any way to test a new created action without actually using the physical input to trigger the action?
Thank you for reaching out with your inquiry regarding the testing of newly created actions. Could you kindly provide more specific information about the device you plan to use and its intended use case? This will help us offer more tailored guidance.
You can test the TRB2 series devices by accessing the device’s WebUI. Please navigate to Services → Input/Output → Status. From there, you can manually switch the output state from “Off” to “On” and invert the inputs to activate the high state.
For TRB1 series devices, such as the TRB141, there are both wet/dry input/output configurations. One of the inputs will require voltage, while others will need a cable connection for activation.
For further details on the Input/Output functionality, please refer to the following link: Input/Output - Teltonika Networks Wiki
If you have additional questions feel free to ask.
