Thx for your Feedback … The Real Mode is not working … My DHCP Client still in mode “searching”
Here the Output
root@Teltonika-TRB500:~# ifstatus mob1s1a1_6
"up": true,
"pending": false,
"available": true,
"autostart": true,
"dynamic": true,
"uptime": 8206,
"l3_device": "rmnet_data0",
"proto": "static",
"device": "rmnet_data0",
"updated": [
"data"
"metric": 2,
"dns_metric": 0,
"delegation": true,
"ipv4-address": [
"ipv6-address": [
"address": "2a00:xx:xxxx:xxxx:xxxx:xxxx:xxxx:xxx",
"mask": 64
"ipv6-prefix": [
"address": "2a00:xx:xxxx:xxxx::",
"mask": 64,
"class": "mob1s1a1_6",
"assigned": {
"lan": {
"mask": 64
"ipv6-prefix-assignment": [
"route": [
"target": "::",
"mask": 0,
"nexthop": "2a00:xx:xxxx:xxxx:xxxx:xxxx:xxxx:xxxx",
"source": "::/0"
"dns-server": [
"2a01:860:0:300::53",
"2a01:860:0:300::153"
"dns-search": [
"neighbors": [
"inactive": {
"ipv4-address": [
"ipv6-address": [
"route": [
"dns-server": [
"dns-search": [
"neighbors": [
"data": {
"modem": "3-1",
"sim": "1",
"zone": "wan"
root@Teltonika-TRB500:~# ifstatus lan
"up": true,
"pending": false,
"available": true,
"autostart": true,
"dynamic": false,
"uptime": 9188,
"l3_device": "br-lan",
"proto": "static",
"device": "br-lan",
"updated": [
"addresses"
"metric": 1,
"dns_metric": 0,
"delegation": true,
"ipv4-address": [
"address": "192.168.2.1",
"mask": 24
"ipv6-address": [
"ipv6-prefix": [
"mask": 64,
"local-address": {
"address": "2a00:xx:xxxx:xxxx::1",
"mask": 64
"address": "fd38:xxxx:xxxx::",
"mask": 64,
"local-address": {
"address": "fd38:xxxx:xxxx::1",
"mask": 64
"route": [
"dns-server": [
"dns-search": [
"neighbors": [
"inactive": {
"ipv4-address": [
"ipv6-address": [
"route": [
"dns-server": [
"dns-search": [
"neighbors": [
"data": {
ifconfig -a
br-lan Link encap:Ethernet HWaddr 00:1E:42:63:23:76
inet addr:100.xx.xxx.xxx Bcast:255.255.255.255 Mask:255.255.255.255
inet6 addr: fd38:xxxx:xxxx::1/60 Scope:Global
inet6 addr: 2a00:xx:xxxx:xxxx::1/64 Scope:Global
inet6 addr: fe80::xxx:xxxx:xxxx:xxxx/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1921260 errors:0 dropped:0 overruns:0 frame:0
TX packets:2175047 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1430641864 (1.3 GiB) TX bytes:1952256829 (1.8 GiB)
ecm0 Link encap:Ethernet HWaddr 00:1E:42:63:23:77
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
erspan0 Link encap:Ethernet HWaddr 00:00:00:00:00:00
BROADCAST MULTICAST MTU:1450 Metric:1
eth0 Link encap:Ethernet HWaddr 00:1E:42:63:23:76
inet addr:169.xxx.x.x Bcast:169.xxx.xxx.xxx Mask:255.255.0.0
inet6 addr: fe80::21e:42ff:fe63:2376/64 Scope:Link
RX packets:1921278 errors:0 dropped:0 overruns:0 frame:0
TX packets:2175020 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1431183122 (1.3 GiB) TX bytes:1952254361 (1.8 GiB)
Interrupt:41
gre0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
NOARP MTU:1476 Metric:1
gretap0 Link encap:Ethernet HWaddr 00:00:00:00:00:00
BROADCAST MULTICAST MTU:1462 Metric:1
ip6gre0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
NOARP MTU:1448 Metric:1
ip6tnl0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
NOARP MTU:1452 Metric:1
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:583 errors:0 dropped:0 overruns:0 frame:0
TX packets:583 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:49514 (48.3 KiB) TX bytes:49514 (48.3 KiB)
rmnet_data0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet6 addr: fe80::xxxx:xxxx:xxxx:xxxx/64 Scope:Link
inet6 addr: 2a00:xx:xxxx:xxxx:xxxx:xxxx:xxxx:xxx/64 Scope:Global
UP RUNNING MTU:1500 Metric:1
RX packets:2024116 errors:0 dropped:0 overruns:0 frame:0
TX packets:1767011 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1867056053 (1.7 GiB) TX bytes:1415818313 (1.3 GiB)
rmnet_data1 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
[NO FLAGS] MTU:1500 Metric:1
rmnet_data2 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
rmnet_data3 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
rmnet_data4 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
rmnet_data5 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
rmnet_ipa0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
UP RUNNING MTU:9216 Metric:1
RX packets:679453 errors:0 dropped:0 overruns:0 frame:0
TX packets:1767011 errors:0 dropped:35 overruns:0 carrier:0
RX bytes:1883248981 (1.7 GiB) TX bytes:1429954401 (1.3 GiB)
sit0 Link encap:IPv6-in-IPv4
NOARP MTU:1480 Metric:1
tunl0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
