TRB500 stops working after running speed-tests
i noticed that if I run a couple of speed-tests using Bredbandskollen
the TRB500 suddenly “stops working”.
I can browse the local 192. admin page, even though even some pages there can be slow.
internet is gone.
rebooting the TRB with the menu-option in the web-gui, then all works as normal again.
did a few speed tests, died again. could reproduce 3-times in a row.
  • any ideas on what is happening here?
  • are there any more detailed logs I can gather to get an idea what’s wrong
thx
Same actually happens when I just stream video on youtube. Almost like the modem itself stops working after about 15 minutes of use.
Can’t see any errors in the logs exposed in the web admin.
bump @Marijus @karolis.muliuolis
would be great with a reply here. is it my physical device or all that has this problem?
Apologies for a late response.
Could you clarify which firmware version (and modem firmware version) is in use on the device?
How many devices are connected to the TRB500?
Has this always been the case, or did it start happening at some point?
OS-info
  • Firmware version: TRB500_R_00.07.06.6
  • Firmware build date: 2024-02-29 18:11:07
  • Internal modem firmware version: RG501QEUAAR12A08M4G_04.200.04.200
  • Kernel version: 4.14.328
Only one laptop/macbook connected to the TRB500
This issue happened first day I used it. Tried updating, factory-restore, but issue persist.
I need to run some higher bandwidth traffic for a while for it to stop routing traffic.
