TRB500 not connecting on 5G after firmware update - Modem Firmware solution not working
I was asked to apply a solution to my TRB500 gateway, but
the firmware update is failing
Any other solution to make this update work?
I had the same issue. The modem upgrader seems to be a bit finicky. Try several times and it should work eventually. Disconnecting the modem or switching to 4G will help too.
