TRB500 Modem firmware request
Hello, I have a TRB500 purchased in october 2023, and it has been unstable since I bought it- no firmwares updates have ever helped, and I tried just about every configuration combination there is.
The issue is always the same- randomly the modem connection fails, only a full reboot solves it. No pattern to it that I’ve noticed. The device is in sweden and using the Tele2 ISP.
Serial no: 6000393632
Batch no: 007
As a last thing to try before I throw it out, I’d like to update the modem firmware, which I have never had the opportunity to try as they are not made available.
Given three years of updates and troubleshooting, if the problem was going to be fixed by a different setting or router firmware update it would have been solved by now, and if I can’t fix this issue that has persisted from factory new before it’s time to upgrade, I sure won’t buy any more teltonikas.
If someone here on the forum knows the right way to get hold of the modem firmware please let me know! Otherwise I’ve seen others with this issue get replies from support staff.
Hello @SmartGlacier82,
To help us better understand the situation and determine the next troubleshooting steps, could you please clarify a few things?
  1. When you say the modem loses connection, do you mean that the device becomes unresponsive, or does it simply lose its connection to the ISP?
  2. Are you using a physical SIM card or an eSIM?
  3. How is the mobile interface configured? Is its mode set to NAT, Bridge, or Passthrough?
  4. Approximately how long does the connection remain active before failing? Does the issue occur after a few hours or a few days?
Additionally, could you please access the device’s CLI through System → Maintenance → CLI in the WebUI and run the following command?
gsmctl -y
This command outputs the exact modem firmware version currently installed on the device.
Note: To access the CLI, use root as the username and the device’s current admin password.
If the device only loses its internet connection while the WebUI remains accessible locally, you can try using the Auto Reboot feature as a temporary workaround.
To configure it:
  1. Navigate to System → Maintenance → Auto Reboot.
  2. Click Edit on the existing instance.
  3. Enable the feature by turning on Enable.
  4. Set Action if no echo is received to either Device reboot or Modem reboot, depending on which option best suits your needs.
  5. Leave the remaining settings unchanged.
  6. If necessary, replace 8.8.8.8 in the Host to ping field with another publicly accessible IP address, such as 1.1.1.1.
This feature can help restore connectivity automatically if the configured host stops responding to pings. Please note that it is only a temporary workaround while we investigate the issue.
We look forward to your response and appreciate your patience and cooperation.
P.
Thanks for the reply.
  1. Internet access is lost, and the device logs gives a series of entries always starting with “Mobile data disconnected (internal modem)”
  2. Physical SIM, i have tried a couple different ones to rule out the sim itself.
  3. The mobile interface is configured to passthrough i have previously ran it as NAT and tried bridge at some point early on to try and get rid of this issue. Currently i have an edgerouter after the TRB500, have had a couple different ones.
  4. It sometimes runs fine for a week, sometimes it fails multiple times in a single day, i haven’t been able to discern any pattern to it.
The modem version: RG501QEUAAR12A07M4G_04.001.04.001
I’m aware of the auto reboot feature and have used it to get some use out of the device.
See below a typical progression- usually there is nothing in the log for hours before “Mobile data disconnected (internal modem)” appears. On some firmware version, i forget which, i could actually just go to status/network/mobile in the webui and click the “restart connection” button, this would work and be way faster than rebooting the entire device. Hasn’t worked for a while though.
I am using this device with external antennas, I have also used it with the included paddles, and a mix of both in order to try to eliminate possible error causes.
2819 2026-10-14 14:50:24 Mobile Data Network Info Mobile data connected (IPv6, internal modem)
2818 2026-10-14 14:50:23 Mobile Data Network Info Mobile data connected (IPv4, internal modem)
2817 2026-10-14 14:50:22 Switch Events Network Notice Port link state of port LAN1 (1000 baseT) changed to UP
2816 2026-10-14 14:50:21 Switch Events Network Notice Port link state of port LAN1 changed to DOWN
2815 2026-10-14 14:50:21 Network Operator Network Info Connected to 24007 operator (internal modem)
2814 2026-10-14 14:50:21 Network Type Network Info Joined 5G-NSA network (internal modem)
2813 2026-10-14 14:49:45 Health checker Network Notice DNS resolution started to fail
2812 2026-10-14 14:49:24 Health checker Network Notice IPv4 connectivity started to fail
2811 2026-10-14 14:49:12 Mobile Data Network Info Mobile data disconnected (internal modem)
2810 2026-10-14 14:49:11 Mobile Data Network Info Mobile data disconnected (internal modem)
@Povilas Any news?
Apologies for thee delayed response.
For further troubleshooting, we will require some sensitive information from your side, such as the device’s Troubleshoot file. These files may contain information such as passwords, public IP addresses, serial numbers, and other potentially sensitive data.
To avoid sharing this information publicly, we have sent you a form to complete. You should receive it at the email address associated with your Community Forum account.
When completing the form, please enter 21502 in the Ticket ID field so that we can associate the submitted information with this thread.
Once you have completed the form, we will continue the communication through a private channel.
Thank you for your patience and cooperation.
P.
