TRB500 Modem fails?
I have a TRB500 setup with a test simcard. Now i’m trying to install it into a production environment but with the eventual simcard installed the device keeps rebooting (which makes it super annoying to debug).
Before it reboots, I can extract the following log lines, what is happening here?
Mon Jul 24 12:12:27 2023 kern.info kernel: [   42.972809] QMI_IPA_INIT_MODEM_DRIVER_REQ_V01 response received
Mon Jul 24 12:12:27 2023 kern.err kernel: [   42.973697] ipa-wan ipa3_check_qmi_response:468 Got bad response 49 from request id 1 (error 48)
Mon Jul 24 12:12:27 2023 kern.err kernel: [   42.983282] ipa-wan rmnet_ipa_get_network_stats_and_update:3341 ipa3_qmi_get_network_stats failed: 1
Mon Jul 24 12:12:28 2023 user.warn kernel: [   44.077692] QTI: DPM Init cb
Mon Jul 24 12:12:28 2023 user.warn kernel: [   44.090962] QTI: DPM Init cb
Mon Jul 24 12:12:28 2023 user.warn kernel: [   44.096986] QTI:DPM port closed
Mon Jul 24 12:12:29 2023 user.warn kernel: [   45.112757] QTI:USB tethered modem SMD port opened
Mon Jul 24 12:12:29 2023 user.warn kernel: [   45.115988] QTI: Modem In Service
Mon Jul 24 12:12:29 2023 kern.err kernel: [   45.351537] ipa-wan ipa3_wwan_ioctl:2045 dev(rmnet_data0) register to IPA
Mon Jul 24 12:12:33 2023 kern.err kernel: [   48.827832] Fatal error on modem!
Mon Jul 24 12:12:33 2023 kern.err kernel: [   48.827901] modem subsystem failure reason: trm_rf_alloc.cpp:942:RF alloc returned FALSE for num_carriers: 5 sub_capability 0.
Mon Jul 24 12:12:33 2023 kern.info kernel: [   48.830167] subsys-restart: subsystem_restart_dev(): Restart sequence requested for modem, tako restart_level = RELATED.
Mon Jul 24 12:12:33 2023 kern.warn kernel: [   48.841741] [harden ]: restart modem,subsystem_restart_wq_func
Mon Jul 24 12:12:33 2023 kern.warn kernel: [   48.853501] [harden] : Quectel_ModemFatalErrProcess ,max cnt :2
Mon Jul 24 12:12:33 2023 kern.warn kernel: [   48.858349] Quectel_modemOnLine_timer_stop, ModemOntimer stop delete now!!!!
Mon Jul 24 12:12:33 2023 kern.warn kernel: [   48.863964] [harden]Quectel_ModemFatalErrProcess, fatal error 3 times, set efs restore flag
Fixed with the firmware update found in TRB500 modem update proceedure
Would have been a real timesaver if this update was on the firmware download page.
