I have a TRB500 being used for failover critical server services. It has been running flawlessly since May with 0 disconnects.
Firmware version. TRB5_R_00.07.02.8
Kernel version 4.14.290
Please note that I haven’t performed any FW updates or other updates.
On 2023-08-12 at 02:11:25, it disconnected from mobile data. And from here, the problem started.
And immediately went out of active operation.
Now, after a couple of days, I did some test and reviewed the logs.
I found that after an uptime of around 45 minutes, the modem disconnects again.
Restarting the modem doesn’t work, a full restart is required. And disconnects again after 45 minutes…
I urgently need assistance in resolving this issue. Any insights, suggestions, or solutions would be greatly appreciated.
(Startup after reboot)
Tue Aug 15 22:52:47 2023 daemon.notice netifd: Interface 'mob1s1a1_4' is enabled
Tue Aug 15 22:52:47 2023 daemon.notice netifd: Interface 'mob1s1a1_4' has link connectivity
Tue Aug 15 22:52:47 2023 daemon.notice netifd: Interface 'mob1s1a1_4' is setting up now
(45 min ish. uptime)
Tue Aug 15 23:37:22 2023 kern.notice kernel: network configuration has been changed
Tue Aug 15 23:37:23 2023 daemon.notice netifd: mob1s1a1 (15310): Stopping network mob1s1a1
Tue Aug 15 23:37:23 2023 daemon.notice netifd: mob1s1a1 (15310): Network cancelled... releasing resources
Tue Aug 15 23:37:23 2023 daemon.notice netifd: mob1s1a1 (15310): [/dev/cdc-wdm0] Network stopped
Tue Aug 15 23:37:23 2023 daemon.notice netifd: mob1s1a1 (15310): Command failed: Not found
Tue Aug 15 23:37:23 2023 daemon.notice netifd: mob1s1a1 (15310): Command failed: Permission denied
Tue Aug 15 23:37:23 2023 daemon.notice netifd: Interface 'mob1s1a1' is now down
Tue Aug 15 23:37:23 2023 daemon.warn dnsmasq[4672]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Tue Aug 15 23:37:24 2023 daemon.notice netifd: mob1s1a1_4 (4860): udhcpc: received SIGTERM
Tue Aug 15 23:37:24 2023 daemon.notice netifd: Interface 'mob1s1a1_4' is now down
Tue Aug 15 23:37:24 2023 kern.err kernel: [ 2690.657325] ipa-wan __ipa_wwan_close:1184 [rmnet_ipa0]: ipa3_deregister_intf failed -22
Tue Aug 15 23:37:24 2023 daemon.notice netifd: Interface 'mob1s1a1_4' is disabled
Tue Aug 15 23:37:24 2023 daemon.notice netifd: Interface 'mob1s1a1_4' has link connectivity loss
Tue Aug 15 23:37:24 2023 user.notice dnsmasq: dhcp_check(): using cached value: 0
Tue Aug 15 23:37:24 2023 daemon.info dnsmasq[4672]: read /etc/hosts - 4 addresses
Tue Aug 15 23:37:24 2023 daemon.info dnsmasq[4672]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Tue Aug 15 23:37:24 2023 daemon.info dnsmasq-dhcp[4672]: read /etc/ethers - 0 addresses
Tue Aug 15 23:37:24 2023 kern.info Mobile data disconnected (internal modem)
