TRB500 FW_TRB500_R_00.07.06.3 blocking webui failed logons even when disabled
Hi All,
We’re experiencing the webui blocking failed logons (While testing scripts to send SMS) even with IP block settings disabled. I have put the fail count up to 100 as a temporary fix. Is this expected behaviour? Is there a fix?
Please try to update a gateway without keeping the settings (all configured settings will be deleted and the router will revert to its default settings) and check if the problem occurs again.
Marija
