I enabled LAN to WAN in the settings. Now I can’t connect via zerotier. Internet is connected via LAN, no SIM card. What settings do I need to change to remotely connect to TRB255 via ZeroTier?
We have an entire configuration guide for ZeroTier that can be found here: ZeroTier Configuration - Teltonika Networks Wiki
Since you did convert the ethernet port to a WAN port, you’ll have to follow this guide to access your device again: LAN as WAN on TRB series - Teltonika Networks Wiki
