TRB255 factory reset issues
Hi!
Total newbie to Teltonika here.
Bought a TRB255 secondhand and needed to factory reset it, since no information on the previous configuration was present.
Holding reset will after 4 sec do a reboot (both connection status and signal strenght LED’s flash) but holding longer will not do anything more. Signal strenght LEDs will not do a countdown.
The device will stay indefinitely in a state where all status LED’s blink together slowly and all signal strenght leds blink together slowly. Status group LEDs and signal strenght group LED not simultaneously.
Login page allso not available.
No SIM installed
Any ideas appreciated.
TIA
Hi…
Maybe you put the device in boot loader mode.
The bootloader menu is a special gateway state used as a recovery tool in case the gateway becomes inaccessible even after a factory reset. It can be used to upgrade the gateway’s firmware or bootloader version.
https://wiki.teltonika-networks.com/view/TRB255_Device_Recovery_Options
So… you PC/MAC/LINUX should be a static ip 192.168.1.2 / 24 (sample)
https://wiki.teltonika-networks.com/view/Setting_up_a_Static_IP_address_on_a_Windows_10_PC
You need to download the firmware for your device, here.
https://wiki.teltonika-networks.com/view/TRB255_Firmware_Downloads
The device was not in booloader mode, but i eventually forced it to bootloader and reinstalled the device. Working now. Thanks
