TRB255 couldn't detect local Mobile Network
I’m From Indonesia, Just bought TRB255 for my IOT project.
however when i try put the Sim card. the number of Sim Card detected but the network disconnect.
I try to change with the other sim card with same provider but the result was same. also with others provider.
The firmware just upgrade toTRB2/TRB2_R_00.07.06.6_WEBUI.bin)
but the result is same.
Need your advice
Have you experimented with a different carrier’s SIM card? Have you successfully connected using older firmware versions? Could you please share the logread from the Command Line Interface (CLI) when you insert the SIM card and connection fails?
Marijus
Dear Marijus,
here with the log read .
root@TRB255:~# “logread”
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 0.000000] Linux version 5.4.259 (app@runner-wcht1mz7-projec
t-352-concurrent-2) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r16279-5cc0535800)) #0 Thu Feb 29 09:15:41 2024
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.000000] printk: bootconsole [early0] enabled
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.000000] CPU0 revision is: 00019374 (MIPS 24Kc)
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.000000] MIPS: machine is Teltonika TRB2XX
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.000000] SoC: Qualcomm Atheros QCA9533 ver 2 rev 0
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.000000] Initrd not found or empty - disabling initrd
Tue Mar 12 12:20:48 2024 kern.warn kernel: [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesi
ze 32 bytes.
Tue Mar 12 12:20:48 2024 kern.warn kernel: [ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases
, linesize 32 bytes
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.000000] Zone ranges:
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.000000] Normal [mem 0x0000000000000000-0x0000000003ffff
ff]
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.000000] Movable zone start for each node
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.000000] Early memory node ranges
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000003fff
fff]
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000
000003ffffff]
Tue Mar 12 12:20:48 2024 kern.debug kernel: [ 0.000000] On node 0 totalpages: 16384
Tue Mar 12 12:20:48 2024 kern.debug kernel: [ 0.000000] Normal zone: 128 pages used for memmap
Tue Mar 12 12:20:48 2024 kern.debug kernel: [ 0.000000] Normal zone: 0 pages reserved
Tue Mar 12 12:20:48 2024 kern.debug kernel: [ 0.000000] Normal zone: 16384 pages, LIFO batch:3
Tue Mar 12 12:20:48 2024 kern.debug kernel: [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=132768
Tue Mar 12 12:20:48 2024 kern.debug kernel: [ 0.000000] pcpu-alloc: [0] 0
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pag
es: 16256
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 0.000000] Kernel command line: console=ttyS0,115200n8 rootf
stype=squashfs,jffs2
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32
768 bytes, linear)
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 163
84 bytes, linear)
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.000000] Writing ErrCtl register=00000000
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.000000] Readback ErrCtl register=00000000
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free
:off
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.000000] Memory: 58688K/65536K available (4021K kernel code,
156K rwdata, 620K rodata, 1208K init, 187K bss, 6848K reserved, 0K cma-reserved)
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1,
Nodes=1
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.000000] NR_IRQS: 51
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.000000] CPU clock: 650.000 MHz
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xf
fffffff, max_idle_ns: 5880801374 ns
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.000010] sched_clock: 32 bits at 325MHz, resolution 3ns, wra
ps every 6607641598ns
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.008973] Calibrating delay loop… 431.10 BogoMIPS (lpj=8622
08)
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.043968] pid_max: default: 32768 minimum: 301
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.049369] Mount-cache hash table entries: 1024 (order: 0, 409
6 bytes, linear)
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.057690] Mountpoint-cache hash table entries: 1024 (order: 0
, 4096 bytes, linear)
Tue Mar 12 12:20:48 2024 kern.warn kernel: [ 0.068856] Duplicate name in mnfinfo, renamed to “name#1”
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.078543] clocksource: jiffies: mask: 0xffffffff max_cycles:
0xffffffff, max_idle_ns: 7645041785100000 ns
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.089671] futex hash table entries: 256 (order: -1, 3072 byte
s, linear)
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.097481] pinctrl core: initialized pinctrl subsystem
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.105352] NET: Registered protocol family 16
Tue Mar 12 12:20:48 2024 kern.warn kernel: [ 0.144306] workqueue: max_active 576 requested for napi_workq
is out of range, clamping between 1 and 512
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.160041] clocksource: Switched to clocksource MIPS
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.167325] NET: Registered protocol family 2
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.172670] IP idents hash table entries: 2048 (order: 2, 16384
bytes, linear)
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.181948] tcp_listen_portaddr_hash hash table entries: 512 (o
rder: 0, 4096 bytes, linear)
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.191570] TCP established hash table entries: 1024 (order: 0,
4096 bytes, linear)
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.200296] TCP bind hash table entries: 1024 (order: 0, 4096 b
ytes, linear)
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.208323] TCP: Hash tables configured (established 1024 bind
1024)
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.215735] UDP hash table entries: 256 (order: 0, 4096 bytes,
linear)
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.223233] UDP-Lite hash table entries: 256 (order: 0, 4096 by
tes, linear)
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.231535] NET: Registered protocol family 1
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.236585] PCI: CLS 0 bytes, default 32
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.246300] workingset: timestamp_bits=30 max_order=14 bucket_o
rder=0
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.260881] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.267564] squashfs: patched 4.0 (2020/11/10) Oever Gonzalez
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.274094] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME)
(CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.303483] pinctrl-single 1804002c.pinmux: 576 pins, size 72
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.316711] shift_io@0 enforce active low on chipselect handle
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.329248] spi-nor spi0.0: xt25f128b (16384 Kbytes)
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 0.335032] 5 fixed-partitions partitions found on MTD device
spi0.0
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 0.342260] Creating 5 MTD partitions on “spi0.0”:
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 0.347722] 0x000000000000-0x000000020000 : “u-boot”
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 0.354605] 0x000000020000-0x000000030000 : “config”
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 0.361474] 0x000000030000-0x000000040000 : “art”
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 0.368117] 0x000000040000-0x000000f70000 : “firmware”
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 0.380113] 2 uimage-fw partitions found on MTD device firmwa
re
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 0.386878] Creating 2 MTD partitions on “firmware”:
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 0.392533] 0x000000000000-0x000000190000 : “kernel”
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 0.399341] 0x000000190000-0x000000f30000 : “rootfs”
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 0.406123] mtd: device 5 (rootfs) set to be root filesystem
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 0.415143] 1 squashfs-split partitions found on MTD device r
ootfs
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 0.422263] 0x000000a50000-0x000000f30000 : “rootfs_data”
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 0.429585] 0x000000f70000-0x000001000000 : “event-log”
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.440853] MNFINFO PROPERTIES:
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.444491] mac : 209727219344
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.448553] name : TRB25500XXXX
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.452608] serial : 6001199753
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.456469] hwver : 0005
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.459725] batch : 0037
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.462992] sim_count: 2
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.465967] blver : 4.2.0
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.469737] Serial: 8250/16550 driver, 1 ports, IRQ sharing dis
abled
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.477979] printk: console [ttyS0] disabled
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.482982] 18020000.uart: ttyS0 at MMIO 0x18020000 (irq = 9, b
ase_baud = 1562500) is a 16550A
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.492816] printk: console [ttyS0] enabled
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 0.501893] printk: bootconsole [early0] disabled
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 1.184180] switch0: Atheros AR8229 rev. 1 switch registered on
mdio.0
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 1.232243] ag71xx 1a000000.eth: connected to PHY at fixed-0:00
[uid=00000000, driver=Generic PHY]
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 1.242381] eth0: Atheros AG71xx at 0xba000000, irq 5, mode: gm
ii
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 1.249015] i2c /dev entries driver
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 1.261465] NET: Registered protocol family 10
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 1.271934] Segment Routing with IPv6
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 1.275977] NET: Registered protocol family 17
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 1.281081] 8021q: 802.1Q VLAN Support v1.8
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 1.287755] gpio-export gpio-export: 4 gpio(s) exported
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 1.302054] VFS: Mounted root (squashfs filesystem) readonly on
device 31:5.
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 1.317849] Freeing unused kernel memory: 1208K
Tue Mar 12 12:20:48 2024 kern.warn kernel: [ 1.322565] This architecture does not have kernel memory prote
ction.
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 1.329231] Run /sbin/init as init process
Tue Mar 12 12:20:48 2024 user.info kernel: [ 1.911687] init: Console is alive
Tue Mar 12 12:20:48 2024 user.info kernel: [ 1.915964] init: - watchdog -
Tue Mar 12 12:20:48 2024 user.info kernel: [ 3.197428] kmodloader: loading kernel modules from /etc/module
s-boot.d/
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 3.387870] usbcore: registered new interface driver usbfs
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 3.393706] usbcore: registered new interface driver hub
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 3.399358] usbcore: registered new device driver usb
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 3.414439] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI)
Driver
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 3.424522] fsl-ehci: Freescale EHCI Host controller driver
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 3.433216] ehci-platform: EHCI generic platform driver
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 3.439027] ehci-platform 1b000000.usb: EHCI Host Controller
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 3.444988] ehci-platform 1b000000.usb: new USB bus registered,
assigned bus number 1
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 3.453242] ehci-platform 1b000000.usb: irq 3, io mem 0x1b00000
0
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 3.472057] ehci-platform 1b000000.usb: USB 2.0 started, EHCI 1
.00
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 3.479660] hub 1-0:1.0: USB hub found
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 3.484292] hub 1-0:1.0: 1 port detected
Tue Mar 12 12:20:48 2024 user.info kernel: [ 3.495019] kmodloader: done loading kernel modules from /etc/m
odules-boot.d/*
Tue Mar 12 12:20:48 2024 user.info kernel: [ 3.504681] init: - preinit -
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 3.768253] usb 1-1: new high-speed USB device number 2 using e
hci-platform
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 3.998052] hub 1-1:1.0: USB hub found
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 4.016428] hub 1-1:1.0: 4 ports detected
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 4.033956] random: procd: uninitialized urandom read (4 byte
s read)
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 4.354248] usb 1-1.2: new full-speed USB device number 3 using
ehci-platform
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 4.564152] usb 1-1.3: new full-speed USB device number 4 using
ehci-platform
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 5.820009] random: jshn: uninitialized urandom read (4 bytes
read)
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 5.930452] random: jshn: uninitialized urandom read (4 bytes
read)
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 6.260437] jffs2: notice: (590) jffs2_build_xattr_subsystem:
complete building xattr subsystem, 30 of xdatum (26 unchecked, 4 orphan) and 44 of xref (3 dead, 2 orphan) f
ound.
Tue Mar 12 12:20:48 2024 user.info kernel: [ 6.278910] mount_root: switching to jffs2 overlay
Tue Mar 12 12:20:48 2024 kern.warn kernel: [ 6.287871] overlayfs: upper fs does not support tmpfile.
Tue Mar 12 12:20:48 2024 user.warn kernel: [ 6.301336] urandom-seed: Seeding with /etc/urandom.seed
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 6.467051] random: mctl: uninitialized urandom read (4 bytes
read)
Tue Mar 12 12:20:48 2024 user.warn kernel: [ 7.803207] - preparing events-log partition -
Tue Mar 12 12:20:48 2024 user.warn kernel: [ 7.916922] Unlocking /dev/mtd7 …
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 8.006409] jffs2: notice: (601) jffs2_build_xattr_subsystem:
complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) foun
d.
Tue Mar 12 12:20:48 2024 user.info kernel: [ 8.097217] procd: - early -
Tue Mar 12 12:20:48 2024 user.info kernel: [ 8.101706] procd: - watchdog -
Tue Mar 12 12:20:48 2024 user.warn kernel: [ 8.780409] [01-serial-symlink.sh] New device ttyS0 at /devices
/platform/ahb/ahb:apb/18020000.uart/tty/ttyS0 appeared!
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 8.822910] random: jsonfilter: uninitialized urandom read (4
bytes read)
Tue Mar 12 12:20:48 2024 user.info kernel: [ 8.840385] procd: - watchdog -
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 8.846043] random: jsonfilter: uninitialized urandom read (4
bytes read)
Tue Mar 12 12:20:48 2024 user.info kernel: [ 8.854741] procd: - ubus -
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 8.901900] random: jsonfilter: uninitialized urandom read (4
bytes read)
Tue Mar 12 12:20:48 2024 user.info kernel: [ 9.017365] procd: - init -
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 9.841623] random: ubusd: uninitialized urandom read (4 byte
s read)
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 9.848741] random: ubus: uninitialized urandom read (4 bytes
read)
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 10.643607] random: jshn: uninitialized urandom read (4 bytes
read)
Tue Mar 12 12:20:48 2024 user.info kernel: [ 10.878433] urngd: v1.0.2 started.
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 11.292761] random: crng init done
Tue Mar 12 12:20:48 2024 kern.notice kernel: [ 11.296365] random: 30 urandom warning(s) missed due to ratel
imiting
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 11.364160] usb 1-1.4: new high-speed USB device number 5 using
ehci-platform
Tue Mar 12 12:20:48 2024 user.info kernel: [ 12.384724] kmodloader: loading kernel modules from /etc/module
s.d/*
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 12.615503] NET: Registered protocol family 15
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 12.626816] Initializing XFRM netlink socket
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 12.636906] tun: Universal TUN/TAP device driver, 1.6
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 12.719087] l2tp_core: L2TP core driver, V2.0
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 12.738399] l2tp_netlink: L2TP netlink interface
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 12.751607] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 12.775314] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 12.794858] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 12.819399] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L
2TPv3)
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 12.838801] gre: GRE over IPv4 demultiplexor driver
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 12.871108] ip_gre: GRE over IPv4 tunneling driver
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 12.978739] ip6_gre: GRE over IPv6 tunneling driver
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 13.276666] tlt-gpio: set names for 18040000.gpio chip
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 13.282871] tlt-gpio: set names for 74hc595 chip
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 13.306253] GACT probability on
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 13.322315] Mirror/redirect action on
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 13.370991] u32 classifier
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 13.373914] input device check on
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 13.377705] Actions configured
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 13.434589] usbcore: registered new interface driver usbserial_
generic
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 13.441543] usbserial: USB Serial support registered for generi
c
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 13.466480] usbcore: registered new interface driver cypress_re
conf
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 13.473182] usbcore: registered new interface driver cypress_se
rial
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 13.479824] usbserial: USB Serial support registered for CY7C65
213
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 13.486333] cypress_serial 1-1.2:1.0: CY7C65213 converter detec
ted
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 13.549072] usb 1-1.2: CY7C65213 converter now attached to ttyU
SB0
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 13.555842] cypress_serial 1-1.3:1.0: CY7C65213 converter detec
ted
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 13.605205] usb 1-1.3: CY7C65213 converter now attached to ttyU
SB1
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 13.746878] usbcore: registered new interface driver cdc_wdm
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 13.843307] usbcore: registered new interface driver ftdi_sio
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 13.849459] usbserial: USB Serial support registered for FTDI U
SB Serial Device
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 14.034797] usbcore: registered new interface driver pl2303
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 14.040764] usbserial: USB Serial support registered for pl2303
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 14.313756] xt_time: kernel timezone is -0000
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 14.562525] usbcore: registered new interface driver option
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 14.568541] usbserial: USB Serial support registered for GSM mo
dem (1-port)
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 14.577007] option 1-1.4:1.0: GSM modem (1-port) converter dete
cted
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 14.583897] usb 1-1.4: GSM modem (1-port) converter now attache
d to ttyUSB2
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 14.591615] option 1-1.4:1.1: GSM modem (1-port) converter dete
cted
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 14.598527] usb 1-1.4: GSM modem (1-port) converter now attache
d to ttyUSB3
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 14.606248] option 1-1.4:1.2: GSM modem (1-port) converter dete
cted
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 14.613173] usb 1-1.4: GSM modem (1-port) converter now attache
d to ttyUSB4
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 14.620898] option 1-1.4:1.3: GSM modem (1-port) converter dete
cted
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 14.627803] usb 1-1.4: GSM modem (1-port) converter now attache
d to ttyUSB5
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 14.808146] PPP generic driver version 2.4.2
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 14.829219] PPP MPPE Compression module registered
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 14.862480] NET: Registered protocol family 24
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 14.890184] PPTP driver version 0.8.5
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 14.923770] qmi_wwan 1-1.4:1.4: cdc-wdm0: USB WDM device
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 14.930584] qmi_wwan 1-1.4:1.4 wwan0: register ‘qmi_wwan’ at us
b-1b000000.usb-1.4, WWAN/QMI device, ea:26:fc:4b:37:0a
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 14.941907] usbcore: registered new interface driver qmi_wwan
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 14.988861] wireguard: WireGuard 1.0.0 loaded. See www.wireguar
d.com for information.
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 14.997037] wireguard: Copyright (C) 2015-2019 Jason A. Donenfe
ld Jason@zx2c4.com. All Rights Reserved.
Tue Mar 12 12:20:48 2024 kern.info kernel: [ 15.108502] l2tp_ppp: PPPoL2TP kernel driver, V2.0
Tue Mar 12 12:20:48 2024 user.info kernel: [ 15.139357] kmodloader: done loading kernel modules from /etc/m
odules.d/*
Tue Mar 12 12:20:48 2024 user.warn kernel: [ 16.453425] [01-serial-symlink.sh] New device ttyUSB0 at /devic
es/platform/ahb/1b000000.usb/usb1/1-1/1-1.2/1-1.2:1.0/ttyUSB0/tty/ttyUSB0 appeared!
Tue Mar 12 12:20:48 2024 user.warn kernel: [ 16.695026] [01-serial-symlink.sh] Creating /dev/ttyUSB0 → /de
v/rs485 symlink…
Tue Mar 12 12:20:48 2024 user.warn kernel: [ 17.319403] [01-serial-symlink.sh] New device ttyUSB1 at /devic
es/platform/ahb/1b000000.usb/usb1/1-1/1-1.3/1-1.3:1.0/ttyUSB1/tty/ttyUSB1 appeared!
Tue Mar 12 12:20:48 2024 user.warn kernel: [ 17.507714] [01-serial-symlink.sh] Creating /dev/ttyUSB1 → /de
v/rs232 symlink…
Tue Mar 12 12:20:48 2024 user.warn kernel: [ 18.108645] [01-serial-symlink.sh] New device ttyUSB2 at /devic
es/platform/ahb/1b000000.usb/usb1/1-1/1-1.4/1-1.4:1.0/ttyUSB2/tty/ttyUSB2 appeared!
Tue Mar 12 12:20:48 2024 user.warn kernel: [ 18.873236] [01-serial-symlink.sh] New device ttyUSB3 at /devic
es/platform/ahb/1b000000.usb/usb1/1-1/1-1.4/1-1.4:1.1/ttyUSB3/tty/ttyUSB3 appeared!
Tue Mar 12 12:20:48 2024 user.warn kernel: [ 19.654771] [01-serial-symlink.sh] New device ttyUSB4 at /devic
es/platform/ahb/1b000000.usb/usb1/1-1/1-1.4/1-1.4:1.2/ttyUSB4/tty/ttyUSB4 appeared!
Tue Mar 12 12:20:48 2024 user.warn kernel: [ 20.425373] [01-serial-symlink.sh] New device ttyUSB5 at /devic
es/platform/ahb/1b000000.usb/usb1/1-1/1-1.4/1-1.4:1.3/ttyUSB5/tty/ttyUSB5 appeared!
Tue Mar 12 12:20:50 2024 daemon.notice procd: /etc/rc.d/S07network: Failed to apply configuration for switch
‘switch0’
Tue Mar 12 12:20:51 2024 user.notice : Added device handler type: bonding
Tue Mar 12 12:20:51 2024 user.notice : Added device handler type: 8021ad
Tue Mar 12 12:20:51 2024 user.notice : Added device handler type: 8021q
Tue Mar 12 12:20:51 2024 user.notice : Added device handler type: macvlan
Tue Mar 12 12:20:51 2024 user.notice : Added device handler type: veth
Tue Mar 12 12:20:51 2024 user.notice : Added device handler type: bridge
Tue Mar 12 12:20:51 2024 user.notice : Added device handler type: Network device
Tue Mar 12 12:20:51 2024 user.notice : Added device handler type: tunnel
Tue Mar 12 12:20:53 2024 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC19
18 responses!
Tue Mar 12 12:20:54 2024 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Tue Mar 12 12:20:55 2024 daemon.info dnsmasq[1935]: Connected to system UBus
Tue Mar 12 12:20:55 2024 daemon.info dnsmasq[1935]: started, version 2.85 cachesize 150
Tue Mar 12 12:20:55 2024 daemon.info dnsmasq[1935]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18
n no-regex no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-cryptohash no-DNSSEC no-ID loop
-detect inotify dumpfile
Tue Mar 12 12:20:55 2024 daemon.info dnsmasq[1935]: UBus support enabled: connected to system bus
Tue Mar 12 12:20:55 2024 daemon.info dnsmasq[1935]: using only locally-known addresses for domain test
Tue Mar 12 12:20:55 2024 daemon.info dnsmasq[1935]: using only locally-known addresses for domain onion
Tue Mar 12 12:20:55 2024 daemon.info dnsmasq[1935]: using only locally-known addresses for domain localhost
Tue Mar 12 12:20:55 2024 daemon.info dnsmasq[1935]: using only locally-known addresses for domain invalid
Tue Mar 12 12:20:55 2024 daemon.info dnsmasq[1935]: using only locally-known addresses for domain bind
Tue Mar 12 12:20:55 2024 daemon.info dnsmasq[1935]: using only locally-known addresses for domain lan
Tue Mar 12 12:20:55 2024 daemon.warn dnsmasq[1935]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto,
will retry
Tue Mar 12 12:20:55 2024 daemon.info dnsmasq[1935]: read /etc/hosts - 4 addresses
Tue Mar 12 12:20:55 2024 daemon.info dnsmasq[1935]: read /tmp/hosts/dhcp.cfg01411c - 0 addresses
Tue Mar 12 12:20:58 2024 daemon.info gsmd[2053]: gsmd-ng init
Tue Mar 12 12:20:58 2024 daemon.info gsmd[2053]: gsmd-ng canary build git#9cf5346253
Tue Mar 12 12:20:58 2024 daemon.info gsmd[2053]: AT traffic support: yes
Tue Mar 12 12:20:58 2024 daemon.info gsmd[2053]: Baseband feature support: no
Tue Mar 12 12:20:58 2024 daemon.info gsmd[2053]: gsmd-ng running
Tue Mar 12 12:21:00 2024 daemon.notice procd: /etc/rc.d/S13openssl: Generating engines.cnf
Tue Mar 12 12:21:01 2024 daemon.err mobifd: Failed to get information about modems
Tue Mar 12 12:21:01 2024 daemon.notice procd: /etc/rc.d/S13openssl: Generating providers.cnf
Tue Mar 12 12:21:01 2024 daemon.notice procd: /etc/rc.d/S13openssl: Enabling legacy
Tue Mar 12 12:21:02 2024 kern.info kernel: [ 36.953101] eth0: link up (1000Mbps/Full duplex)
Tue Mar 12 12:21:02 2024 kern.info kernel: [ 36.968925] br-lan: port 1(eth0) entered blocking state
Tue Mar 12 12:21:02 2024 kern.info kernel: [ 36.974433] br-lan: port 1(eth0) entered disabled state
Tue Mar 12 12:21:02 2024 kern.info kernel: [ 36.980310] device eth0 entered promiscuous mode
Tue Mar 12 12:21:02 2024 kern.info kernel: [ 37.061375] br-lan: port 1(eth0) entered blocking state
Tue Mar 12 12:21:02 2024 kern.info kernel: [ 37.066876] br-lan: port 1(eth0) entered forwarding state
Tue Mar 12 12:21:02 2024 daemon.notice netifd: Interface ‘lan’ is enabled
Tue Mar 12 12:21:02 2024 daemon.notice netifd: Interface ‘lan’ is setting up now
Tue Mar 12 12:21:02 2024 daemon.notice netifd: Interface ‘lan’ is now up
Tue Mar 12 12:21:02 2024 daemon.notice netifd: bridge ‘br-lan’ link is up
Tue Mar 12 12:21:02 2024 daemon.notice netifd: Interface ‘lan’ has link connectivity
Tue Mar 12 12:21:02 2024 daemon.notice netifd: Interface ‘loopback’ is enabled
Tue Mar 12 12:21:02 2024 daemon.notice netifd: Interface ‘loopback’ is setting up now
Tue Mar 12 12:21:02 2024 daemon.notice netifd: Interface ‘loopback’ is now up
Tue Mar 12 12:21:02 2024 daemon.notice netifd: bridge ‘br-lan’ link is down
Tue Mar 12 12:21:02 2024 daemon.notice netifd: Interface ‘lan’ has link connectivity loss
Tue Mar 12 12:21:02 2024 daemon.notice netifd: Network device ‘eth0’ link is up
Tue Mar 12 12:21:02 2024 daemon.notice netifd: Network device ‘lo’ link is up
Tue Mar 12 12:21:02 2024 daemon.notice netifd: Interface ‘loopback’ has link connectivity
Tue Mar 12 12:21:03 2024 daemon.info gsmd[2053]: [ubus_notify_event:299] error: [MODEM_UBUS] Failed to send u
bus notify for 1-1.4 [2c7c:0296] modem!
Tue Mar 12 12:21:03 2024 kern.info kernel: [ 37.940215] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes
ready
Tue Mar 12 12:21:03 2024 daemon.info mobifd: [gsm.modem0] Starting modem settings init
Tue Mar 12 12:21:05 2024 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Tue Mar 12 12:21:06 2024 daemon.err dnsmasq[1935]: failed to send packet: Network unreachable
Tue Mar 12 12:21:07 2024 daemon.info mobifd: [gsm.modem0] SIM is ready
Tue Mar 12 12:21:07 2024 daemon.info mobifd: [gsm.modem0] Will attempt to enable roaming service
Tue Mar 12 12:21:07 2024 daemon.crit mobifd: [gsm.modem0] Modem will be reloaded due to a change in settings
Tue Mar 12 12:21:07 2024 daemon.err dnsmasq[1935]: failed to send packet: Network unreachable
Tue Mar 12 12:21:08 2024 kern.info kernel: SIM state changed to not inserted (internal modem)
Tue Mar 12 12:21:08 2024 daemon.err dnsmasq[1935]: failed to send packet: Network unreachable
Tue Mar 12 12:21:09 2024 daemon.err dnsmasq[1935]: failed to send packet: Network unreachable
Tue Mar 12 12:21:10 2024 daemon.err dnsmasq[1935]: failed to send packet: Network unreachable
Tue Mar 12 12:21:11 2024 daemon.info mobifd: [gsm.modem0] Config reload initiated
Tue Mar 12 12:21:11 2024 daemon.info mobifd: [gsm.modem0] SIM is ready
Tue Mar 12 12:21:12 2024 daemon.err dnsmasq[1935]: failed to send packet: Network unreachable
Tue Mar 12 12:21:14 2024 daemon.info mobifd: [gsm.modem0] Modem settings init completed
Tue Mar 12 12:21:14 2024 daemon.info mobifd: [gsm.modem0] Starting connection setup
Tue Mar 12 12:21:14 2024 daemon.info mobifd: [gsm.modem0] APN “telkomsel” isn’t prepa
Please wait a bit longer, at least a few minutes, before accessing the logread. Currently, there isn’t any useful information available since there are only 3 seconds of logs after inserting the SIM.
Additionally, please consider trying other troubleshooting methods mentioned in my previous message.
Marijus
