TRB245 RS232 Polarity
Hi, I sent some data via RS232, and I can see that the data is inverted.
Is there an option in the TRB245 configuration to “uninvert” the signals ?
  • Søren
The inversion is a part of the RS232 design. However, it should only affect the lowest level logic.
There is no option to invert the output of the RS232 signal in RutOS, and as far as I can tell, all devices follow this standard. Could you clarify why this is needed?
I got it work, it was the scope I used that was funky, not the TRB245 :slight_smile:
