TRB245 GPGGA latitude and longitude incorrect
I use TRB245 to get GPS data.
Latitude and Longitude data in GPS/Map in the control panel are correct, but the coordinate data I get with GPS/NMEA GPGGA is incorrect.
How can I fix GPGGA data?
I found my mistake. I converted the latitude and longitude values ​​to degrees. The problem is solved.
Solved img :
