TRB143 M-bus to MQTT
Hi I got a problem with a TRB143 sending the MBUS-data over MQTT as JSON.
What I get sent up to the MQTT server is the following:
I would expect to get some kind of data from the Mbus module.
The M-bus is set up as Json
and DAta to server has the following setup:
Type: m-bus data
Format Type Json
Data Filtering: All
Segment Count : 1 with “Send as Object” marked
And Database is in RAM
Furthermore i use a MQTT broker of another type, but that shoulde be the problem since i can read what showed in the picture.
