We are experiencing an issue with the Teltonika TRB143 when sending data collected from M-Bus devices to an external MQTT broker using the Data to Server functionality.
The system operated reliably for several months. However, approximately six weeks ago, problems started occurring. We have since upgraded the TRB143 to the latest available firmware versions, but the issue persists. The currently installed firmware is RutOS R_00.07.24.7.
Problem description
Initially, the device operates correctly and publishes MQTT messages containing the expected M-Bus measurements. However, after some time, the MQTT messages continue to be delivered to the broker, but the measured values are missing from the payload.
Importantly, the M-Bus service continues to operate normally, and data acquisition appears to be successful:
- The Successful requests counter continues to increase.
- The Database entries counter also continues to increase.
- MQTT messages continue to be published to the broker.
- The MQTT connection remains established.
This suggests that the M-Bus data is being collected and stored correctly, but is not being included in the MQTT payload by the Data to Server service.
Rebooting the TRB143 temporarily resolves the problem, and the MQTT payload once again contains the expected M-Bus measurements. However, the issue eventually reoccurs.
Current MQTT configuration:
Broker: private
Port: 8883
QoS: 1
Enable secure connection: Disabled
UCI configuration: data_sender.2.mqtt_tls=‘0’
Despite TLS being disabled, packet captures using tcpdump clearly show TLS Application Data records (17 03 03 ...) in both directions.
Questions
Is this a known issue in RutOS or the
datasenderservice, where M-Bus data is successfully acquired and stored in the database but stops appearing in MQTT payloads? -
What could cause the Data to Server service to stop retrieving M-Bus measurements even though the Successful requests and Database entries counters continue to increase?
Is there a way to enable detailed DEBUG logging for
datasender, particularly for database queries, payload generation, MQTT PUBLISH operations and PUBACK acknowledgements? -
Does
datasenderautomatically enable TLS when connecting to port 8883, even whenmqtt_tls=0? -
Is there a recommended way to restore normal operation without rebooting the entire device, for example by restarting only the
datasenderservice? -
Are there any known fixes or workarounds for this behavior in recent firmware releases?
Since the system worked correctly for several months and the problem appeared only recently, we would also appreciate any information about possible software regressions or known issues affecting the integration between M-Bus data acquisition, the internal database and the Data to Server MQTT service.
We can provide configuration files, system logs and TCP packet captures if required.
Thank you for your assistance.
Best regards
kamils
