TRB143 Huawei Solar
I use Teltonika trb143. It communication with carlo gavazzi via Modbus tcp. i read all data no any problem.
I have a solar system and I use Huawei sun2000 solar driver. I can read all data with mbpoll (modbus tcp reader) on my computer, there is no problem.
But I cant read the Huawei data in Teltonika trb143.
What can be the problem?
Best regards
please provide me with the following information:
  1. try to ping from your TRB143 to your Huawei device and vice versa. Please send me the screenshot of this result.
  2. please provide the screenshot of the Modbus configuration on both sides of the devices.
Thank you.
Alam N.
I couldn’t figure out how to ping via TRB143.
But I can connect to the solar driver via Modbus Poll and read the data.
I can also ping from the computer
TRB143 settings
please follow these references to run the ping method on your TRB143 to ensure network connectivity between your TRB143 and Huawei device has been established:
  1. Using the Diagnostics feature in the WebUI, TRB143 Maintenance - Teltonika Networks Wiki (teltonika-networks.com)
  2. Run the ping command via CLI, TRB143 Maintenance - Teltonika Networks Wiki (teltonika-networks.com)
Thank you.
Alam N.
