We are using a Teltonika TRB140 with firmware version TRB1_R_00.07.24.5
Our goal is to use the device as an SMS gateway with SMPP.
Current configuration
SMPP Server: Enabled
Port: 2775
Username: admin
TLS: Disabled
Ethernet configured as WAN (lan_to_wan)
Static IP: 10.8.1.133
Mobile connection active and registered to the operator network
SMS sending works successfully
Derdack Enterprise Alert
SMPP 3.4
Host: 10.8.1.133
Port: 2775
System Identifier: admin
SMPP password configured
Single Port Connection enabled
What works
TCP connection established successfully
SMPP authentication successful
BIND_TRANSMITTER successful
BIND_RECEIVER successful
SMS can be sent through TRB140
Received SMS messages are visible in TRB140 Messages/Inbox
What does NOT work
When an SMS is sent to the SIM card installed in the TRB140:
SMS appears in the TRB140 inbox
Derdack never receives the message
No DELIVER_SM packet is observed on the SMPP client side in Derdack SMPP log
Questions
Does TRB140 firmware TRB1_R_00.07.24.5 fully support MO SMS delivery over SMPP (DELIVER_SM)?
Is any additional configuration required to forward received SMS messages to connected SMPP clients?
Are there any logs that can show SMPP DELIVER_SM processing on the TRB140?
Is there a CLI command or diagnostic log that can be used to troubleshoot SMPP inbound message delivery?
I would appreciate any guidance on how to verify whether the TRB140 attempts to send messages to Derdack for received SMS.
Thank you.
