TRB140 Not Upgrading from TRB1_R_00.07.03.4
Hi, I have had my last TRB140 lost the modem. Rectory reset nothing.
So I purchased a new TRB140 (TRB14010XXXX) but is has FW “TRB1_R_00.07.03.4” so I went to OTP upgrade to “TRB1_R_00.07.15” which appears to work, yet after a reboot it always returns to “TRB1_R_00.07.03.4”.
Any suggestions to get this device to actually upgrade and stay upgraded.
I have also tried downloading and applying as a file upload. nope.
Then tried scp the file to /tmp and sysyupgrade.. no luck.
Finally I imported into RMS and tried upgrade via RMS still nothing… stays at old version.
Have factory reset.
PS: Also tried “TRB1_R_00.07.04_WEBUI.bin” which is only one release after the current. still nothing.
Any suggestions?
Many thanks.
Thank you for reaching out. To assist you effectively, we’ll need to continue this process privately. You should find a support request form in the inbox of the email address you used for your forum registration. Kindly fill out the form, and please reference Ticket ID: 14164 when submitting it. Once the form is completed, we’ll contact you directly via email to help and assist you in working towards a potential resolution.
