I have installed a TRB140 on a closed net. The only access is through a VPN or TRB140.
But I have no DNS resolution, so am unable to connect to RMS.
I am wondering if my LAN setup is correct.
I set up a standard GW in LAN settings, and thus might have prevented DNS resolution over WAN.
Is my solution to remove the GW in LAN settings.?
I am a bit hesitant to do it, if I should lose connection.
It is a 500 km drive
How is the device able to reach the internet? Is it through a VPN tunnel?
You can navigate to Network → Intefaces → Edit LAN → Advanced settings and add DNS servers there. These DNS will be available for DNS resolution on all interfaces. You can also take a look at this post here.
Besides DNS, if you want to use RMS, you need to make sure that the RMS is reachable from your closed network. Please, take a look at this page here where you can find the IP addresses and port numbers that you need to open.
