TRB140 /api/messages/actions/send "modem" field
I am affected by API changes that force me to rewrite my software because a formerly supported API endpoint to send SMS just got removed. As others pointed out, this is a major no-go. Our devices are connected to a PC with a 1:1 ethernet connection, so there is no reason to worry about plain text passwords in the URL component (which are otherwise a stupid idea, yes)
https://developers.teltonika-networks.com/reference/trb140/7.20.3/v1.12.1/messages#post-messages-actions-send
How do I find out, what to put into the “modem” field when sending SMS? Is there an API endpoint that lists all available modems? How do I pick the right one? This info wasn’t needed in the previous API.
Greetings, André
The TRB140 has a single modem.
You can send a GET request to the /modems/status endpoint. The response will include the modem ID, which on most devices is “1-1”
More details can be found here:
https://developers.teltonika-networks.com/reference/trb140/7.20.3/v1.12.1/modems#get-modems-status
