Hello there,
(at least) the package Travelmate in missing in the package distribution RUTX_R_00.07.10
Travelmate exists in previous release RUTX_R_00.07.09.4
Does anyone know about this?
Thanks Cheers Phil.
Travelmate is now embedded in the firmware itself, and you no longer need to install the package.
To answer your question of “Does anyone know about this?” … Yes, as it was published in the release notes for RUTX_R_00.07.10
Hello Mike, Thanks for the quick answer. I admit I’ve not seen this “detail” in the OS release notes.
Nevertheless: despite the Travelmate package was markes as invalid with RUTX_R_00.07.10, the function was still available in the GUI. This means I could have “guessed” that Travelmate is still present. Now I’ve remove Travelmate package 7.09.x and all works fine.
Good idea to have integrated it.
Good to see you’re up and running.
As Mike mentioned, the Travelmate package is now included in the device by default, so you no longer need to install it manually via packages.
Please let me know if you have any further questions regarding this topic.
