Toyota Hilux (Brazil) - LVCAN200 + FMC150 connection scheme and CAN library request
I’m installing an FMC150 with LVCAN200 on a Toyota Hilux 2015-2024 here in Brazil, and I need help with the following:
  1. Connection scheme for the CAN H and CAN L wires for Hilux models (Brazilian market) - which wires/pins/colors to connect on the vehicle side.
  2. Which CAN library (program number) should be used on the LVCAN200 for the Hilux.
  3. Which CAN library should be used on the FMC150 for this vehicle.
Vehicle details:
  • Vehicle: Toyota Hilux
  • Year: [coloque o ano do seu Hilux]
  • Trim/version: [SR / SRX / SRV / GR-Sport / etc.]
  • Keyless system: [Yes / No]
  • Market: Brazil
Could someone please send me the PDF with the LVCAN200 connection scheme and program number, along with the correct CAN library for the FMC150?
Thank you in advance!
Additional info: the exact model is Toyota Hilux CS4X4CHAS (Single Cab, 4x4, Chassis), year 2014.
