Sometimes, I return to a question that I’ve asked some weeks ago, and realise that I could drastically improve it, without whatsoever changing the topic of the question. Instead of it going unanswered, I should be able to improve it. However, the post modification window is short. As discussions.fedoraProject.org demonstrates, this can very feasibly be indefinitely, to the betterment of the forum.
Two years ago, unanswered topics were closed after 15 days, but this rule has not been in effect for quite some time now. Currently, topics are closed only when the “Solution” button is pressed on one of the comments.
I see that you have created a new topic referring to your older topics. An engineer will be assigned to it and will provide you with an answer.
@Marija, my sincere thanks. However, I am not referring to closure. I am referring to the ability to modify the content, via:
Apologies for not fully understanding you.
If the topic is not closed, you should still be able to edit it. If you have any issues editing open topics or would like me to reopen any of your closed topics, please let me know and provide the links.
@Marija, you likely see that due to your administrative position on this instance. However, for me, some hours after I submit a topic or comment, it always becomes unmodifiable thereafter:
For comparison, on a recently-created comment, I observe:
It’s due to a preference on this Discourse instance.
