Tmux Crashing After Firmware Update
I installed tmux on my OpenWrt device using the following command:
opkg -e /etc/opkg/openwrt/distfeeds.conf install tmux
However, during the installation, I encountered a warning:
Configuring tmux.
find: /etc/tmux.conf: No such file or directory
After the installation, when I tried to launch tmux with the tmux command, I received the error message:
[server exited unexpectedly]
What could be causing the crash and how can I fix it?
If you use the /etc/opkg/openwrt/distfeeds.conf configuration file for opkg, you are installing packages from repositories other than Teltonika’s. These packages have not been thoroughly tested with our devices, so they may not work properly. For packages that have been tested and are guaranteed to work, please use the /etc/opkg/openwrt/teltonikafeeds.conf feeds file.
Thanks for your response. Unfortunately, tmux is no longer available for installation using etc/opkg/openwrt/teltonikafeeds.conf. While this package worked fine with firmware version 7.4, it is not functioning with version 7.7.
