Tmt250 sending data over tcp/ip issue
So we are trying to do a handshake between TMT250 and a server. We do reply 0x01 and tracker wont send the data to a server. Any help?
import socketserver
class MyTCPHandler(socketserver.BaseRequestHandler):
    The request handler class for our server.
    It is instantiated once per connection to the server, and must
    override the handle() method to implement communication to the
    client.
    def handle(self):
        # self.request is the TCP socket connected to the client
        self.data = self.request.recv(1024).strip()
        print("{} wrote:".format(self.client_address[0]))
        print(self.data)
        print("Sending Server Accept 0x01 byte to client")
        self.request.sendall(b'\x01')
        # here you can do self.request.sendall(use the os library and display the ls command)
if __name__ == "__main__":
    HOST, PORT = "0.0.0.0", 8999
    # Create the server, binding to localhost on port 9999
    with socketserver.TCPServer((HOST, PORT), MyTCPHandler) as server:
        # Activate the server; this will keep running until you
        # interrupt the program with Ctrl-C
        server.serve_forever()
Could you please send me the screenshot of the data that you receive from the device?
Did you configure your server on the device?
