TMT250 send data to Java socket server over TLS
I have a Java based server running a Server socket. The socket is configured with a SSL keystore containing the server certificate (private & public key) together with the CA certificate used to sign these keys. I also uploaded the same CA certificate to my TMT250 device.
When trying to connect to the server I always get a bad certificate error in the server log. When I try out the connection from within a simple Java client application having a truststore with the CA certificate in it configured, everything is working fine.
I followed this documentation : TLS traffic encryption between Teltonika devices and flespi
When I do the same towards the Flespi platform, everything works fine. The problem I’m facing is similar to Uploaded certificate to FMC125 and turning TLS on is not working - Crowd Support Forum | Teltonika GPS
Without TLS activated on the device and on the server, the messages are processed correctly.
Thanks for your help!
What do I do wrong. Is there more extended documentation available?
Good day,
Please try to follow instructions on how to generate the certificates from this page:
https://wiki.teltonika-gps.com/view/How_to_generate_TLS_certificates_(Windows)%3F
If you will have any questions, forward them in this topic.
Regards
Thanks for replying. I’m using easyrsa on Ubuntu. These are the commands that I execute:
make-cadir dev2
cd dev2
./easyrsa init-pki
./easyrsa build-ca nopass
./easyrsa --subject-alt-name=“DNS:myhost.com” build-server-full platform nopass
Consequently I should configure pki/issued/platform.crt as a server certificates chain and pki/private/platform.key as a server private key on my Java server in a keystore. Apparently I don’t manage to do that correctly using keytool. Can you point out the precedure?
Thanks!
Good day,
It seems that in DNS it is set as myhost.com - is this the correct domain? Have you tried using the external IP address of your server as the ALT name?
Kind regards
The hostname is indeed different but not want to put it here.
In the meantime I managed to get it fixed by recreating the keystore.
Johan,
