I’m using teltonika RUT900 and sim card to creat an remote access with open VPN.
As you can see from the attached photo, I have a problem with RSRP and SINR signal quality.
Reception of the 4g signal from the sim card is fine. When I activate the wifi I have no connection problems. In fact when I try to access my PLC network via the open VPN I can do absolutely nothing. It’s as if the quality of the connection between the router and my PLC was limited.
