Teltonika TRB500 versions
Hi
I bit not technical guestion but just wanted to ask to make sure. I didn’t manage to find answer to this.
There seems to be two “versions” of this in the market. One is with grey casing and one with black, are they totally same? No version one newer one older etc things?
Just wanted to make sure that there is no difference between color of these products before purchasing one?
Thank you.
Good afternoon,
The TRB500 can be found in grey or black casing, it all depends on when the device was manufactured.
Arturas
ok, but technically the insides are identical? :slight_smile:
Just want to make sure that i will be bying the more current device. As I have had exprience afterwards that devices might have some strange hardware v1, v2 etc.
Thank you
That is correct, the devices are the same, only the casing differs.
That is however how the devices leave our facilities. If the item is purchased from a distributor, we cannot guarantee that they have not swapped the insides, accessories etc, if that is what you are inquiring.
Arturas
