I have a device that is constantly moving and needs to change Access Points while roaming. I am using the Multi AP option and it is working but i wanted to know if it is possible to change from 5 ghz to 2.4 ghz automatically when the signal is weak. Is there an option on RUTX10 to make that possible?
Yes, if you enable fast roaming, set them up in the same mobility domain and have the same SSID it would then switch automatically, most likely even quite fast when connection is lost.
Not sure how effective the switch back to 5GHz would be
