Teltonika RUT955 cannot ping IP address local Sangfor through IPSEC VPN
Hi Support,
i got issue :
sangfor —> teltonika (behind from sangfor, I can ping ip add device back teltonika)
Teltonika ----> sangfor (behind from teltonika, I cannot ping add device back sangfor)
Sangfor Technical already check config sangfor, he say that sangfor configure no issue. i need to know teltonika need allow from ping ip from outsite to local?
Just to clarify, You can ping 192.168.3.2 from 192.168.50.x but cannot ping 192.168.50.x from 192.168.3.x.
There are a few things to look out here.
  1. Do a traceroute to see where the ping gets dropped.
  2. Make sure that you added the remote subnet properly in the IPSec settings of the RUT955.
    You can add a screenshot of your IPSEC settings (Kindly Redact any personal and sensitive information).
    Clive Pinto
