Hi, I have Teltonika RUT360 with last firmware that doesn’t handle properly OpenVPN Client.
There are many up&down on the router for OpenVPN Client.
With different model of Teltonika, I don’t have this problem.
I import OpenVPN certificate directly on RUT360.
Any idea? I would try with another firmware
Have you tried the same configuration with the same firmware versions as on your RUT360, or with different ones?
Additionally, please let me know if you have experienced this issue before.
I try with another model of Teltonika with differents firmware and it works
With RUT360 not work
I would like to review the troubleshoot file from your RUT360. Please fill out the form I have sent you, and once completed, I will contact you privately. For the ticket ID, please use “9256”.
Thank you!
