Teltonika l2tp client+eoip
Sveiki,
Naudojame mikrotik kaip vpn serverį, o teltonika rutm56 sukonfigūruotas l2tp klientas su eoip. Problema, kad eoip tunelis nepakyla, reikia pagalbos, kad surasti kur problema.
Have you followed the configuration example in this guide?
L2 LAN bridging over internet using L2TPv2+EoIP - Teltonika Networks Wiki
If you did, for troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 16626.
