I tried to use FMB140 on a Puma Case, program No. 13525.
I updated the CAN adapter in fota web. When we did the instalation and connected the Teltonika unit, it does not changed the program number and I think the autoscan also did not work.
Do I need something different to work with this type of Brand/Model? Or is the unit not set the right way?
This is the data in bin.
<TOT_REC>1</TOT_REC>
Low
1715864533;A;49177571;13457381;188;0;698
240
32
0
0
<FMx100_CSQ val=“5” id=“21”>5</FMx100_CSQ>
0
<GPS_POW val=“1” id=“69”>1</GPS_POW>
0
11
7
13078
<BAT_mV val=“4063” id=“67”>4063</BAT_mV>
<BAT_mA val=“0” id=“68”>0</BAT_mA>
0
<LVC_railF_dir val=“11120” id=“100”>11120</LVC_railF_dir>
Thank you
Veronika
