Teletonika RUT240 password
Default Login Password is not admin01. What ist actualy the Default Password
Could you try resetting the device to check if another password has been set? This can be done by holding the reset button until all signal LEDs light up.
Additionally, new devices use unique passwords. If this is the case, the password can be found on the back of the device.
If neither of these steps help, there might be a deeper issue with the device and it may need to be returned for warranty repair.
Thank you for your Help. I have found now the Password on the back of the device.
