Is there a problem with RMS? I still have no solution for the below.
I create a VPN hub but it cannot detect devices connected to the RUT241. When I use the RUT241 interface and scan the topology all of the units appear. I have manually created a subnet on the VPN hub but I cannot connect to any of the devices remotely. I have also configured the connected devices individually and cannot connect. Masquerading is turned on.
I can connect to all of the devices when I am locally connected to the device. Remote connection does not work.
