I seem to struggle a lot with connection losses and I hope to improve the performance of the router by selecting a range for either dynamic or static lease of the IP’s. Can someone indicate how I can do that?
Thank you for reaching out.
If you are referring to changing the IP lease range on the router’s LAN DHCP server, this can be done by navigating to Network → DHCP → Server Settings, then clicking Edit to adjust the lease range as needed:
Let me know if you need further assistance.
Thank you and yes have done that. But how is it then possible that under Status-Network-Lan-DCHP leases i find static leases?
