I’m new to this platform (RUT956) so I expect there’s a simple answer to why the following script isn’t running at startup. In other posts I’ve seen reference to the echoed strings going into some system log. If that is correct, where is that system log? The script runs fine when I run it from the command line.
At startup the mkdir commands don’t even create the subdirectories. The /home/root/MTIEnt directory exists and the init script is in that directory.
Any thoughts appreciated.
Thanks, Dave
#!/bin/ash
echo “MTI startup script ***************************”
sleep 20
echo “MTI startup script AFTER SLEEP ***************************”
mkdir /var/usr/MTIEnt
mkdir /var/usr/MTIBase
cd /home/root/MTIEnt
./initMTI.sh &
echo “END MTI startup script ***************************”
exit 0
