Startup Script failing on FW 7.14.2
I have a problem where some commands no longer work when running them from the Startup Script.
The commands giving issues are:
Ubus
timeout
/etc/init.d/rms_mqtt restart
They code works perfectly when running them from CLI.
Here is my code:
#!/bin/ash
sleep 30
LOGFILE=“/tmp/startup_debug.log”
echo “===== Script Start: $(date) =====” >> “$LOGFILE” 2>&1
echo “Restarting MQTT service…” >> “$LOGFILE” 2>&1
if [ -x /etc/init.d/rms_mqtt ]; then
/etc/init.d/rms_mqtt restart >> “$LOGFILE” 2>&1
else
echo “MQTT init script not found” >> “$LOGFILE”
fi
serial_Nr=$(cat /sys/mnf_info/serial 2>> “$LOGFILE”)
echo “Serial: $serial_Nr” >> “$LOGFILE” 2>&1
BROKER=Broker_Ip
PORT=Port
TOPIC=“/${serial_Nr}_WR”
RESPONSE_TOPIC=“/${serial_Nr}_WR/response”
USERNAME=“Username”
PASSWORD=“Password”
QOS=0
RETRY_INTERVAL=10
MAX_RETRIES=10
echo “TOPIC: $TOPIC” >> “$LOGFILE” 2>&1
echo “RESPONSE_TOPIC: $RESPONSE_TOPIC” >> “$LOGFILE” 2>&1
check_internet() {
ping -c 1 -W 1 8.8.8.8 >> “$LOGFILE” 2>&1 || curl -s --head --max-time 2 https://www.google.com >> “$LOGFILE” 2>&1
return $?
ensure_package_installed() {
package_name=“$1”
max_retries=5
retry_interval=30
retry_count=0
while true; do
    if opkg list-installed | grep -q "^$package_name " >> "$LOGFILE" 2>&1; then
        echo "Package '$package_name' is already installed." >> "$LOGFILE" 2>&1
        return 0
    fi
    echo "Checking internet connectivity..." >> "$LOGFILE" 2>&1
    while ! check_internet; do
        retry_count=$((retry_count + 1))
        if [ "$retry_count" -ge "$max_retries" ]; then
            echo "No internet connectivity after $max_retries attempts. Exiting for now. Retry later." >> "$LOGFILE" 2>&1
            exit 1
        fi
        echo "No internet connection. Retrying in $retry_interval seconds... ($retry_count/$max_retries)" >> "$LOGFILE" 2>&1
        sleep "$retry_interval"
    done
    opkg -e /etc/opkg/openwrt/distfeeds.conf update >> "$LOGFILE" 2>&1
    echo "Attempting to install package '$package_name'..." >> "$LOGFILE" 2>&1
    if opkg -e /etc/opkg/openwrt/distfeeds.conf install "$package_name" >> "$LOGFILE" 2>&1; then
        echo "Package '$package_name' installed successfully." >> "$LOGFILE" 2>&1
        return 0
    else
        echo "Failed to install package '$package_name'. Retrying in $retry_interval seconds..." >> "$LOGFILE" 2>&1
    fi
done
required_packages=“curl coreutils-timeout mosquitto-client-ssl”
for package in $required_packages; do
ensure_package_installed “$package”
done
attempts=0
while ! ubus list | grep -q modbus_client && [ $attempts -lt 10 ]; do
echo “Waiting for modbus_client UBUS service…” >> “$LOGFILE”
sleep 5
attempts=$((attempts+1))
done
for i in $(seq 1 $MAX_RETRIES); do
echo “Attempting to connect to MQTT broker (Attempt $i)…” >> “$LOGFILE” 2>&1
mosquitto_pub -h $BROKER -p $PORT -t "/test/connection" -u $USERNAME -P $PASSWORD -m "test" -q $QOS >> "$LOGFILE" 2>&1
if [ $? -eq 0 ]; then
    echo "Connected to MQTT broker successfully." >> "$LOGFILE" 2>&1
    mosquitto_sub -h $BROKER -p $PORT -t $TOPIC -u $USERNAME -P $PASSWORD -q $QOS | while IFS=',' read -r ID FUNCTION FIRST_REG VALUE DATA_TYPE IP_ADDRESS
    do
        echo "Received command: ID=$ID, FUNCTION=$FUNCTION, FIRST_REG=$FIRST_REG, VALUE=$VALUE, DATA_TYPE=$DATA_TYPE, IP_ADDRESS=$IP_ADDRESS" >> "$LOGFILE" 2>&1
        if ubus list | grep -q modbus_client; then
            RESPONSE=$(ubus call modbus_client.rpc tcp.test "{
                \"id\": $ID,
                \"timeout\": 5,
                \"function\": $FUNCTION,
                \"first_reg\": $FIRST_REG,
                \"reg_count\": \"$VALUE\",
                \"data_type\": \"$DATA_TYPE\",
                \"no_brackets\": 1,
                \"ip\": \"$IP_ADDRESS\",
                \"port\": \"502\",
                \"delay\": 0
            }" 2>> "$LOGFILE")
                echo "Command executed successfully. Response: $RESPONSE" >> "$LOGFILE" 2>&1
                timeout 4 mosquitto_pub -h $BROKER -p $PORT -t "$RESPONSE_TOPIC" -u $USERNAME -P $PASSWORD -m "$RESPONSE" -q $QOS >> "$LOGFILE" 2>&1
            else
                echo "Failed to execute write command." >> "$LOGFILE" 2>&1
                echo "Response was: $RESPONSE" >> "$LOGFILE" 2>&1
            fi
        else
            echo "modbus_client not available after waiting. Skipping." >> "$LOGFILE"
        fi
    done
    break
else
    echo "Failed to connect to MQTT broker. Retrying in $RETRY_INTERVAL seconds..." >> "$LOGFILE" 2>&1
    sleep $RETRY_INTERVAL
fi
done
if [ $? -ne 0 ]; then
echo “Failed to connect to MQTT broker after $MAX_RETRIES attempts.” >> “$LOGFILE” 2>&1
exit 1
fi
echo “===== Script End: $(date) =====” >> “$LOGFILE” 2>&1
And the log returned:
===== Script Start: Tue May 13 11:20:16 UTC 2025 =====
Command failed: Not found
Serial: Serial Nr
TOPIC: /Serial Nr_WR
RESPONSE_TOPIC: /Serial Nr_WR/response
Package ‘curl’ is already installed.
Package ‘coreutils-timeout’ is already installed.
Package ‘mosquitto-client-ssl’ is already installed.
Attempting to connect to MQTT broker (Attempt 1)…
Received command: ID=1, FUNCTION=3, FIRST_REG=401, VALUE=1, DATA_TYPE=16bit_uint_hi_first, IP_ADDRESS=192.168.0.8
Response was:
Apologies for the delay. Could you please let me know if you’ve managed to find a solution for this issue on your end already?
If not, after reviewing your script and logs, at first view, it looks like the issue likely resides in the syntax of your ubus call modbus_client.rpc tcp.test command.
Specifically, the JSON arguments inside the brackets should be enclosed in single quotes '{<variables>}' rather than double quotes for the entire payload. Here’s a corrected example of how the command should be structured:
ubus call modbus_client.rpc tcp.test '{"id":1,"timeout":1,"function":3,"first_reg":1,"reg_count":"2","data_type":"16bit_int_hi_first","no_brackets":1,"ip":"192.168.50.138","port":"502","delay":"0"}'
Could you adjust your script accordingly and see if this resolves the command failures you were experiencing in the startup environment?
Let me know if the issue still persists or if it was resolved.
