SSH and Public Key
how i can put the public rsa key to the teltonika tsw202?
If I paste it manually under ssh → edit → Public Key, it does not work.
Thanks for help.
Could you confirm whether the public RSA key was pasted as a single line without any extra spaces or line breaks? Additionally, can you successfully SSH from your local machine using the private key?
If pasting manually does not work, you can try adding the public key through SSH to the /etc/dropbear/authorized_keys file.
Also, for optimal performance, please ensure that your TSW202 is running the latest 1.5 firmware.
Thanks for Your answer. I think that I could use the private key for ssh.
Now there is a key in the ssh WebUI-Box and it works. But I’m not sure how I’ve got it.
But it is working.
Again Thank you.
Thank you for confirming, and it’s working now.
If you ever need further assistance, feel free to reach out.
