RUT950 and RUT9_R_00.07.04.3
Neither SQM or QOS are available. QOS was available on previous major FW version.
Also see: RUTX09: Mobile interface not available for SQM - Crowd Support Forum | Teltonika Networks
Currently, setting a mobile interface through the WebUI is unavailable. However, our team is already aware of this limitation and is addressing it.
In the meantime, you can change the setting via the mobile interface using the command line:
First, set up QoS for a different interface, such as the WAN. Next, access your device’s command line and execute the following command:
- vi /etc/config/qos
This command will launch a text editor. Press ‘i’ to enter the editing mode. Use the arrow keys to navigate to your configuration for the WAN interface and replace ‘wan’ with ‘mob1s1a1’.
To save your changes, press ESC, then type ‘:wq’ and hit enter. Finally, restart QoS with this command:
- /etc/init.d/qos restart
Now, QoS should operate correctly on the mobile interface.
Thank you!
Both for confirming that you’re working on it and also for providing workaround!
