SMS GPS returns "No fix"
Hi, I have been using RUTM_R_00.07.17.5 with my RUTM11 and have been able to interrogate GPS location by sms using the gps command, however having updated the firmware to RUTM_R_00.07.18.2 all I get back is “No fix”, I checked the GPS system and location though the GUI and all is fine. I am uncertain how I report this issue with this firmware. I have now reverted the firmware back and all works again as it had.
I use RUTX50 with 7.18.3 and have same problem. Position on map is ok. NMEW Collecting is ok. But after sms rewuest i get “no fix” at result.:upside_down_face:
Greetings, Bertha,
Thank you for your message,
I have managed to replicate the issue on my end as well. For further investigation, I have escalated this case to our R&D department. A temporary fix would be to use an older stable version of the firmware. Once I have news, that the issue is resolved, I will let you know.
Just to avoid confusion,
The firmware version I was referring to is RUTM_R_00.07.17.5 which can be downloaded from this wiki article:
Best regards.
I would like to inform you that this issue will be fixed in firmware version 7.21.
We appreciate your patience and understanding.
