SMS fw_upgrade command fails when %fs=NO despite available firmware update (RUT200/241)
We are experiencing an inconsistency when using the SMS command for firmware upgrade on a RUT200/241 device.
Scenario:
  • When sending an SMS command with fw_upgrade:
    • If the parameter %fs=NO → the device returns:
Error encountered while executing command
    • If the parameter %fs=YES → the firmware upgrade process starts successfully.
Issue:
When %fs=NO, the command fails immediately without checking whether a newer firmware version is available.
However:
  • When accessing the Web UI, there is an available firmware update (banner is displayed).
  • This indicates that the device is aware of a newer version, but the SMS command does not validate this before failing.
Expected Behavior:
The fw_upgrade command (with %fs=NO) should:
  1. Check if a newer firmware version is available.
  2. Only return a failure if no update exists.
  3. Otherwise, proceed or at least return a meaningful status (e.g., “update available but not forced”).
Questions:
  1. Why does the fw_upgrade SMS command fail when %fs=NO without checking for available updates?
  2. What is the exact logic behind %fs (force upgrade?) in this context?
  3. Is this expected behavior or a firmware bug?
  4. Is there a recommended way to trigger a “check-and-upgrade-if-needed” via SMS?
Additional Info:
  • Device model: RUT200/241
  • Firmware version: RUT2M_R_00.07.21.2
  • SMS command format used: fw_upgrade
Greetings @Bracha,
Our apologies for the delayed response.
The %fs parameter is used to check whether a newer firmware version is available for your device on the FOTA server.
A response of %fs=NO indicates one of the following:
  • There is no newer firmware version available on the FOTA server for your device.
  • The router does not have internet access and therefore cannot reach the FOTA server.
A response of %fs=YES indicates that:
  • The router has internet connectivity to the FOTA server.
  • A newer firmware version is available for the device.
Please note that the %fs command only checks for available updates. It does not initiate the firmware upgrade.
The fw_upgrade SMS command will fail if the response to %fs is NO, as this means either the device cannot reach the FOTA server or it is already running the latest available firmware.
At the moment, there is no built-in SMS command that performs a “check-and-upgrade-if-needed” only if one is available" operation. Achieving this behavior would require additional scripting.
By default, you can use the Send Status SMS rule to check whether a new firmware version is available. If the response indicates that an update is available, you can then send the Firmware upgrade from server SMS rule to initiate the firmware upgrade.
Additionally, could you please clarify your intended end goal? Are you looking to implement this functionality using the built-in SMS Utilities, or are you planning to use additional scripting to automate the process?
Povilas
Hello Povilas,
Thank you for your response and for clarifying how the %fs parameter works.
I would like to explain my use case in more detail.
I have more than 10 routers of the same model deployed in different locations. Once I know that a new firmware version has been released (for example, because one router reports %fs=YES or I see the new version published), I would like to send the same fw_upgrade SMS command to all of my routers.
However, this is currently not possible because the fw_upgrade command fails whenever %fs=NO.
Regarding the explanation that %fs=NO may indicate that the router cannot reach the FOTA server, I do not believe this is relevant in my case. My routers are permanently connected to the Internet. If a router had no Internet connectivity, I would first resolve the connectivity issue before attempting a firmware upgrade.
The issue is that fw_upgrade appears to rely only on the previously reported %fs status. Instead, I believe it should perform a fresh check against the FOTA server each time the command is executed.
My suggestion is that when the router receives the fw_upgrade SMS command, it should first contact the FOTA server and check whether a newer firmware version is available.
  • If a newer firmware version is available, it should immediately start the upgrade.
  • If the router is already running the latest firmware, it should simply return a message such as “No newer firmware available.”
  • If the router cannot reach the FOTA server, it should return an appropriate connectivity error.
This approach would make remote firmware management much more practical, especially for deployments with multiple routers, where I want to send the same SMS command to all devices without first checking the %fs status of every individual router.
I believe this would significantly improve the usability of the SMS firmware upgrade feature.
Hello @Bracha,
Our deepest apologies for the delayed response.
We were able to reproduce the issue and are currently investigating the possible cause.
We have also forwarded the information and your questions to our R&D team for further investigation. We will get back to you as soon as we receive any additional information from them.
We appreciate your patience and cooperation.
P.
